for the guys that swapped in lt1s into second gens
Old Apr 5, 2004 | 02:50 AM
93formula's Avatar
what harness and pcm did you use and why.
what transmission did you guys use and why.
what did you use for the fuel system.
any websites with pics will be extremely helpfull.
as you can see from my other posts i have a dilema with what pcm to use, what harness to use, and what transmission to use.
i have in my possesion, a 93 pcm and harness, a 97 pcm and harness, a accel dfi, a t56 with everything, a 4l60e.
id like to use one of the stocker harnesses if possible.
also the car is a 79 its going into which was formally a auto car, so whatever route will be the easiest is the way id like to go. rigth now im leaning toward the th350.
reprogramming of the pcm is not one of my concerns, i know someone who can burn chips for the 93 pcm, and i have access to tunercat for the obd1 pcm.
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
Ricardo
Nov 29, 2014 10:58 AM
Jul 4, 2005 05:00 PM
Red97LT1
Aug 7, 2002 05:45 PM
