67 Wheel Question
Old Mar 30, 2004 | 10:21 PM
TEG99SS's Avatar
67 Wheel Question
Does anybody out there know if 4th gen salad shooters will fit a 5 lug 67 camaro?
I found a torn up 67 with 4 flat tires and before I go all the way to where I keep my extra sets of wheels, I would like to know if they will fit.
I just need to get the car home and it would help if I knew if they will bolt right on!!!
Scored the car for $500.00 !!!!
Thank you!!!
Old Mar 31, 2004 | 03:19 PM
SS69MAN's Avatar
They should be 4.75" on 5" bolt circle on the 67. Not sure about the newer ones. Make sure you take the lug nuts. Oh.......and studs on the 67 are fairly short. Take that into consideration
Old Mar 31, 2004 | 03:47 PM
jg95z28's Avatar
Aren't the 4th gen bolts metric?
Old Apr 1, 2004 | 05:42 PM
Dave89IROC's Avatar
bolt pattern is the same, backspacing is different, you would need adapter/spacers, I dont know how thick, but to use 4th gen wheels on a 3rd gen, you need 2 in spacers on all four corners
Old Apr 1, 2004 | 07:37 PM
Green95Z28's Avatar
goto kragens or autozone and you can pick up a cheap set of lug nuts if yours don't work.
P.S. I am very sure you are gonna need spacers
Old Apr 5, 2004 | 05:55 PM
TEG99SS's Avatar
Thanks for the help guys, Salad shooters don't belong on a 67 anyway, I will deal with the tire problem another way.
Tom G
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Airplanedoc
Feb 1, 2015 07:14 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
ChrisFrez
Nov 30, 2014 08:41 AM
redzed
Sep 4, 2002 06:22 PM
