engine combo
Old Jul 20, 2005 | 01:34 PM
  #16
angel71rs's Avatar
Re: engine combo
Originally Posted by confused327
i have the engine apart . it has 1.74 valves
Ah, good old powerpack heads no doubt. These were actually the hot tip.... in 1957.
Old Jul 20, 2005 | 02:45 PM
  #17
confused327's Avatar
Re: engine combo
its a 1969???
Old Jul 20, 2005 | 08:18 PM
  #18
Re: engine combo
what would everyone think of a set of vortec heads with maybe a different cam????
Old Jul 20, 2005 | 08:59 PM
  #19
stale's Avatar
Re: engine combo
I've heard vortecs are the **** for a stock buildup. If you're not trying to hot rod that 327, the stock port sizes and flow rates would be great for a mild street motor. Drop those in with a cam like they used in that article I posted. Just get the flat tappet version with the same overlap and lift.
Old Jul 21, 2005 | 08:05 PM
  #20
angel71rs's Avatar
Re: engine combo
its a 1969???
The Power Pack heads were used in hi perf sbcs in the 50's. In the 60s, the same design was used in low perf versions of 327s. I think they stopped using the Power Packs ~67-68, so if your 327 is a 69, won't have them. You can spot Power Packs at 20 paces due to the large triangle shape cast into front of head.
Vortec heads are killer low buck specials. Great flow. With a cam around 218-224*, would make excellent streetable power. Make camel hump heads look like crap. Check this chart out. Vortecs outflow the best 60s heads (186, 461, 462) at .400 - .500" lift:
http://users.erols.com/srweiss/tablehdc.htm#BBChevy
Ported 461s win out at .600, but that is meaningless in a street engine.
Old Jul 21, 2005 | 08:40 PM
  #21
Re: engine combo
mine arent power packs, they dont have the triangle thing. the vortecs may be the next thing to come but i really want to just get the car on the road so i will probably just jet some junkyard 1.94's for now. thanks for the help eveyone!!!
oldschool
Feb 9, 2016 09:21 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
92ragtop
Dec 27, 2014 01:56 PM
Nostang 96z
Sep 15, 2002 10:15 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
