Door won't open
Old Feb 23, 2004 | 01:04 PM
MTmace's Avatar
Door won't open
I locked my door this weekend, now it won't open.
The key won't turn and I can't pull up on the ****, it is simply stuck. I removed the door panel, with the door closed and can't figure out what I need to do to open the door.
By the way it is a 68.
Any help?
MTmace
Old Feb 23, 2004 | 11:37 PM
StorminNorm's Avatar
Spray the mechansim w/ WD40
Unscrew the door lock
Take some pliers and grab the threaded lock pin and yank up and down until you pull up on the lock mechansm inside. Work some more WD40 on the mechanism and this should do it - not a permanent solution as it will always jam if you try to open the door w/ the lock on. keep a pair of pliers in the car.
Old Feb 24, 2004 | 05:20 PM
MTmace's Avatar
Thanks for your response, I tried the WD40. I will keep trying.
MTmace
DirtyDaveW
Dec 1, 2016 05:37 PM
Heathen1
Jan 2, 2016 04:27 PM
bowtieboy95
Jul 1, 2015 06:49 AM
97z28k&N
Jan 9, 2015 04:58 AM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
