Car won't start?
Old May 22, 2003 | 09:32 PM
htrd69's Avatar
Car won't start?
I have been trying to get my 69 RS going, but am having a problem. I have had it tore apart since winter and am trying to finish it up. I have been doing some minor wire relocating and have wired in a MSD 6AL and was hoping to fire it up tonight but I am not getting anything. Turn the key, and nothing. It doesn't move the volts gauge and doesn't affect the headlights when there on. Fuel pump is working, lights are working, just won't crank over.
A little more about the wiring, I unhooked the harness from the fuse panel and completly redid the coil wire. I am running an hei and took the resistor wire out and replaced it with a regular wire. I also wired up the MSD while I was doing all this. I ran the headlight harness under the fender behind the wheelwell and bolted everything back up.
I am going to look over everything again tomorrow or the next day to make sure that everything looks right. The brake light is also staying on until I turn the key on and then it goes off.
I am open to suggestions or helpful hints!
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
