Cam Help!
Old Mar 8, 2006 | 12:14 AM
Leif-o's Avatar
Cam Help!
Alright so I'm building a 355 out of an 80 or so block. Non roller of course and I'm going to do a stealthram setup on it. My problem is the camshaft. I bought one but it was for a roller equipped block and the spread on the cam gear is too small. I can't find a comupter compatible hydraulic roller cam for an older block with a button style cam gear. The problem with the cam I have now is that it has the beveled edge for the lock plate on a hydraulic roller block.Do they make a timing set with the new spread with a hole in the middle for the cam button? Does anyone know anyway around this? What have other people done? any help would be great.
Old Mar 8, 2006 | 05:47 AM
BitterOldMan's Avatar
Re: Cam Help!
You do NOT want to use a roller cam in with non-roller lifters. You will catch an edge and wipe a lobe in short order. Go get a flat-tappet or upgrade to roller lifters.
Old Mar 8, 2006 | 09:30 AM
Leif-o's Avatar
Re: Cam Help!
I';ve got the roller lifters the only problem is the cam gear.
Old Mar 8, 2006 | 09:48 AM
Rice Killer87's Avatar
Re: Cam Help!
Call Summit or Jegs,im pretty sure theres a way around it.
Old Mar 8, 2006 | 02:23 PM
Leif-o's Avatar
Re: Cam Help!
well I went and talked to a machinist today and he said to get an aluminum or nylon button and turn it down until it fits. I will also have to make a plate to keep the rollers in the middle of the cam where the retainer plate would have been.
Old Mar 9, 2006 | 02:52 AM
1racerdude's Avatar
Re: Cam Help!
Get the Crane conversion kit,it has all that. Talk to Crane to see which kit they recommend. Ya got to have the holders in the valley to hold the rollers streight.
Old Mar 9, 2006 | 10:26 AM
Leif-o's Avatar
Re: Cam Help!
got the retrofit lifters already. I just made a washer like plate last night to go onto the end of the cam and keep the cam from sliding too far into the block. It centered everthing up in the block very nicely. Now I just need to get the crank gear on and I'll be ready to make a button for it.
Old Mar 12, 2006 | 09:59 PM
camaro75racer's Avatar
Re: Cam Help!
Are you using the retro hydraulic or solid roller lifters? If your using the solid roller DO NOT FORGET the oil restrictors. I know from experience the chaos caused if you dont.
Old Mar 13, 2006 | 01:49 PM
Leif-o's Avatar
Re: Cam Help!
I've got the hydraulic roller lifters. and yea I've heard horro stories before.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
