Brake Lights suddenly dont work...
Old Mar 14, 2004 | 08:59 PM
StorminNorm's Avatar
First it was the right one. Now its both. The tail lamps both work but nothing when i hit the brakes. The bulbs both look fine or is could both be bad and i cant see it?
Would it be a fuse even though the tail lamps work?
Old Mar 14, 2004 | 09:04 PM
jg95z28's Avatar
Can you still see two separate filaments in each bulb?
Old Mar 14, 2004 | 09:07 PM
ill have to pull them and look through a magnifying glass. Check
ed one and it looked connected.
i just hate driving around w/ no brake lights.
Old Mar 14, 2004 | 09:16 PM
jg95z28's Avatar
So does the guy behind you.
I think there may be separate fuses for the brake and tail lights though. That might be easier to check with a flashlight.
Old Mar 14, 2004 | 09:23 PM
jg95z28's Avatar
Nope. I just checked my 67. Same 20A fuse for STOP and TAIL LAMP.
It's most likely the bulbs.
Old Mar 14, 2004 | 09:34 PM
Thanks - i'll take it slow. Should have picked up some bulbs this afternoon like i planned. But i forgot that my weekends dont belong to me anymore.
Old Mar 14, 2004 | 10:27 PM
jg95z28's Avatar
Tell me about it. I spent the day working on my kid's car while he was out hanging with his friends.
Old Mar 14, 2004 | 10:31 PM
We have to learn to be selfish. My daughter wants a 1st gen Mustang. She thinks i'm going to deliver one to her perfectly w/ power windows - power door locks - nice new AC system. She's wrong.
Old Mar 15, 2004 | 05:19 PM
OK - help me out here - replaced both bulbs - both tail lamps work - I wasnt able to see if either brake light works but the hazzards definitely dont work (neither lights up) - I know for a fact that one hazzard will flash if the other bulb is out. But now - neither hazzard flashes.
Now - I see that there was a loose ground wire coming from the right (passenger) side taillamp. It is attached to one of the screws on the bezel housing - it is white and has a blue collar on it but I cannot for the life of me figure out where it is suppose to go. There are two wires that come out of the taillamp bulb and there arent any open connections along that harness that runs along the back of the trunk.
Any ideas?
Old Mar 15, 2004 | 05:31 PM
jg95z28's Avatar
Have you tried replacing the flasher? I'm not sure if that impacts the brake lights but it might. I don't think the ground is the problem, otherwise the tail lamps wouldn't work either.
I'm trying to remember.... is there a switch on the brake pedal that activates the brake lamps? Maybe that's the next place to look if the flasher isn't the problem.
Old Mar 15, 2004 | 05:40 PM
What exactly is the "Flasher" and where is it?
Its odd - sometimes the dash lef/right signals (when I put on the hazzards) flash slow - sometimes fast.
Old Mar 15, 2004 | 06:04 PM
jg95z28's Avatar
The its got to be the flasher. On the firewall, near fuse box, small spherical looking device about an inch across. (see pic) Sometimes referred to as flasher relay.
http://www.automotive-lighting.com/p...ashers_big.jpg
GM should be a 552 if I remember correctly.
Old Mar 15, 2004 | 06:14 PM
jg95z28's Avatar
AKA turn signal relay... plus I was just looking for pics online and came across a Chevy reference as a "Turn Signal / Stop Lamp" relay.
Old Mar 15, 2004 | 06:22 PM
These damn cars - one thing after another and the symptoms are so inconsistent. Wait - that's all cars.
So - that's the problem you think? I guess its worth a shot.
I just checked the bulb socket on the right tail lamp (the one that went out initially) as the metal inside looks deformed. I dont know - maybe that's it as well.
Any chance the major auto parts stores carries these bulb sockets or am I about to spend some $$ from Classic Industries?
Old Mar 15, 2004 | 06:52 PM
Not the relay - cant be - just realized that the front turn signals work. Its the socket and Pep Boys has them!
