Bought the 67 Camaro i showed you before
Old Jul 19, 2003 | 06:25 PM
joink's Avatar
Bought the 67 Camaro i showed you before, what gas should i use?
I had you guys review a 67 camaro for me a couple weeks ago.
Most of you said not to pay more than 10k for it but i paid 11k and i am very happy with it.
This car has a 327 with a 4brl carb and headers on it. I was wondering what grade fuel and oil types are best for these motors. I have almost no experience with classic cars.
What do you guys use to keep you cars running well?
Old Jul 19, 2003 | 08:41 PM
unvc92camarors's Avatar
i dont know any answers to your questions, but congrats on buying the car!
dont worry, even if you paid 11k i'm sure the satisfaction of having it will make up for that extra grand you threw down
Old Jul 21, 2003 | 07:30 AM
jy211's Avatar
I use 93 octane in all my old cars. Also every once and a while I will run a 50/50 mix of 93 and race fuel. As far as oil goes I use 20w50 for higher mileage engines.....
Old Jul 21, 2003 | 10:54 AM
jg95z28's Avatar
And don't forget to use a lead additive if the heads haven't been redone.
Old Jul 21, 2003 | 06:32 PM
joink's Avatar
why do they require such high octane? The standard in AZ seems to be 87,89,91. I have been using 91 and the car seems to run fine.
Old Jul 21, 2003 | 08:27 PM
jg95z28's Avatar
Then run 91. As for me, I'm running Union76 92 in my 67.
Old Jul 21, 2003 | 09:35 PM
Hellbilly69's Avatar
sheeze...I run 87 in mine and it runs fine. I've got a 1999 350 crate and it'd run off garbage if you could get it in the carb. Maybe since it's 35 years old you should run 91/92 then.
Old Jul 22, 2003 | 08:15 AM
Jeff H's Avatar
You need to find out more information on the 327 in your car. Is it original, is it the 210hp or 275hp version? The 210 hp version doesn't need more than 87 or 89 octane to run fine. The 275 hp version is higher compression so you would want to run 91 if possible.
Old Jul 22, 2003 | 10:35 AM
jg95z28's Avatar
Really? Thanks. I'll try 87 next time and see how it runs.
Old Jul 24, 2003 | 07:11 PM
JEDCamino's Avatar
I think the 210hp 327 may have been a two barrel carb. You definitely need to find out if the engine is all original, mainly to see if it has hardened valve seats (for unleaded gas).
ChrisFrez
Jan 4, 2015 08:43 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
