Big Block over-heating Need HELP!!!
Old Jun 26, 2009 | 10:47 AM
Joes96z's Avatar
I have a 96 camaro with a 496 big block, that i installed over the past year. At idle for about 10-15 minutes it gets to about 215 and then it keeps going up. I have tried different fans and radaitors but still happens. I did a exhaust gas test and it passed. I am running water with water wetter and a 160 stat. I need help big time, I dont know what else to try before I have to start thinking about taking the heads off. Any info would help
thanks, joey
Old Jun 26, 2009 | 11:36 AM
Z28SORR's Avatar
Not much info.
Why would you pull the heads?
How do you know these temperature are accurate?
Where are you getting the temp. reading from?
How is the flow though the cooling system?
What, if any, changes were made the the old system?
What pump, rad. fans. etc. etc. are you using?
Old Jun 26, 2009 | 04:00 PM
Joes96z's Avatar
Pull the heads to check the head gaskets.
I have the temps from the mech. gauge and using a laser temp light
flow looks good
Radiator Griffen 27.5x15.5 single pass 1 inch tubes
Radiator griffen 16x27.5 double pass with 1.5 tubes
fans I have tried
14 in single 1500 CFM
14 inch 2850 CFM no shroud
duel 12 inch fans with shroud
Edlbrock Mech. waterpump
Old Jun 29, 2009 | 07:50 AM
blown94's Avatar
pressure test the system and cap. possible you got an air pocket in there still? try bleeding the system.
Old Jun 29, 2009 | 09:43 AM
Z28SORR's Avatar
But you've done this.
What about the cowling in front of the rad.? Are there any gaps that would allow the air to "get around" the rad.
Definately strange.
Old Aug 26, 2009 | 07:41 PM
pearlpurple's Avatar
Bad or backwards thermo?????
geinsteder
May 6, 2015 06:02 AM
MadMav
Feb 6, 2015 11:02 PM
OutLaw305
Jul 26, 2002 03:47 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
