Bang for Buck, LS1 vs 350
Old Aug 23, 2009 | 06:30 PM
  #31
1980berlinettaZ's Avatar
Originally Posted by Kraest
Hard to say what heads you need unless you know what pistons you have. I know that 72cc usually yield SOMEWHERE around 9-9.5:1 on a 350 SBC, but those are with flat-tops or 5cc valve reliefs. ...
If your car truly has 8:1 compression, you probably have dished pistons somewhere in the 20cc range and would need to be somewhere in the 50cc range to have anything that resembles power.
Plus, those heads you listed are garbage 165cc intake-runner iron heads. Next.
Those heads are probably better than the stock ones i have on now, but i never searched the part number to seet hat it was only 165cc... i thought bottom of the line iron heads were 180cc.
And your right they are the lousy dished pistons with valve releif and chamfered edge. Probably the worst piston GM ever put out. I think the old domed pistons prior to 1974 were even of better quality.
I was thinking about going with the "D" shaped pistons, they are supposed to work good on low compression motors.
It seems alot of perf LT1 or L82 has flat-tops, so they shouldn't be too hard to find right?
REDNECKISBOSS
Apr 13, 2015 07:55 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
kksi
Feb 16, 2015 06:49 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
LT1runner
33
Jul 24, 2002 01:19 PM
