69 camaro Z28 head casting #'s
Old Aug 29, 2008 | 03:09 PM
git_sum's Avatar
I picked up a set of heads today and the casting numbers are 3927186. They're double hump heads but they have the acc. holes drilled from the factory. I was doing a google search and it showed that 69 z28 302 camaro's only had these casting cylinder heads. Can anyone varify this?
Old Aug 29, 2008 | 05:16 PM
cnorton's Avatar
That casting number as well as 3947041 was found on the '69 Z28 motor. Of course, both would have had the accessory holes on the ends. Both of those numbers could have been found on other 1969 and 1970 engines as well. The Z28 application used 2.02 intake and 1.60 exhaust valve sizes. The 350 applications called for 1.94 intake and 1.50 exhaust valves.
*Emilia*
May 13, 2015 09:05 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
NED4SPD
Sep 16, 2002 10:45 PM
