Is a 69 10 bolt and a 81 10 bolt the same?
Old Jan 6, 2005 | 07:09 PM
Chris`s85Z28's Avatar
My bother in law has a 4:10 gear set outta a 69 camaro 10 bolt he says it`s an 8.5" ring gear, will the gears fit in my 81 Z28`s rear?
Old Jan 6, 2005 | 07:34 PM
angel71rs's Avatar
Re: Is a 69 10 bolt and a 81 10 bolt the same?
Stock 69 10 bolts were 8.2's. So unless someone swapped in an 8.5 diff into that 69, gears won't fit. 8.5 has 30 splines on pinion shaft, 8.2 has about 25.
Old Jan 6, 2005 | 08:13 PM
ok so if the gears ARE 8.5`s they`ll fit right, I`ll count the splines on the pinion to see if there 8.5`s or 8.2`s I hope there 8.5`s. The rear end these gears are outta is in a 74 nova, I`m think he said it`s outta a 69 camaro, but I`m not sure, would the gears be 8.5`s if the rear end is really a 74 nova rear???
Old Jan 6, 2005 | 09:53 PM
ninetythreez's Avatar
Lightbulb Re: Is a 69 10 bolt and a 81 10 bolt the same?
just get the whole rear end..direct bolt up...hehehe
Old Jan 8, 2005 | 01:30 AM
angel71rs's Avatar
If diff was originally from a 74 Nova, it's an 8.5.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
