XM radio antennae
Old Jun 15, 2006 | 11:03 PM
nervekiler's Avatar
XM radio antennae
so thats where i put mine.. it works surprisingly well there and i didnt have to put it outside and scratch up my paint.. just used double sided tape and ran the wire under the dash peice there (just pull on it.. itll pop up just held in with pressure clips and velcro)
hope this helps some people out.
Old Jun 15, 2006 | 11:06 PM
Klypto's Avatar
Re: XM radio antennae
yea, i sell these things daily... most ppl think you need to put it outside the car... half the installs i see are inside, and work fine...
good job there
cory
Old Jun 16, 2006 | 07:42 AM
m6speed's Avatar
thats where i plan on putting mine also
Old Jun 16, 2006 | 11:36 AM
anasazi's Avatar
how do you have a dash from 1995 that isn't cracked?
and on topic, i put my antenna inside my engine bay on top of the passenger shock tower, works perfect.
Old Jun 16, 2006 | 07:18 PM
2muchcoffeeman's Avatar
Mine's on the plastic piece between the T-tops, right above the windshield. Wire loops under the plastic piece across the metal area the passenger-side top rests in, then is shoved up into the door-surround molding on the front side of the right door. Wire enters the car at the grommet where other wires enter and is hidden up in the dash on the passenger side where nobody can tangle with it.
No problems with signal loss or anything else.
Old Jun 16, 2006 | 07:36 PM
Grims's Avatar
Lmao, what do you not have a hood or something?
Old Jun 17, 2006 | 05:27 AM
Rashiki's Avatar
The shock tower setup works great if you have a fiberglass hood, and is even cleaner than the dash pad install.
Hey nervekiller, yer car is running hot :P Time for a manual fan switch!!
Old Jun 17, 2006 | 01:25 PM
nervekiler's Avatar
i was kinda worried at first about puttin the ANT on the dash right there and also my alarm LED.. but its cool cause i dont have to brag about having XM anymore a lot of my friends ride with me and after a whiel they are like hey you have XM?! im like yeah.. what type of music you listen to?
its all oohhs and ahhs after that.
haha manual fan switch.. all i need is a reason ot put one of those on i actually read somewhere though that you make more power if the engine is running a certain temp i think it was around 180* or something.. if its too cool then the oil gets a little thicker.. this was all about oil temp on old engines.. but i just like to pretend if its not way up in the red then i am fine. haha
its hard driving a black car in the desert but it hardly gets hotter than that.
Old Jun 17, 2006 | 08:56 PM
Grims's Avatar
I always thought XM relied on LOS, interesting to know it's not.
nosliw
Mar 9, 2016 04:56 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
Bxlt1
Sep 10, 2015 08:16 AM
