Wiring in a capacitor
I have a capacitor that has no manual with it so I'm not positive on how to wire it.
I wired i inline with the power and ground cables so basically I just cut the cables and hooked up the wires to the capacitor. Will that work?
The + of the cap gets connected inline with the Positive cable. The - side gets wired to ground.
You need to "charge" it with a resistor, or you're going to get one hell of a spark when you go to connect to your battery or fuse.
Well, it's already hooked up and I didn't get any sparks so I should be ok, right?
It is a used one that had been in a car before but it's been sitting in my basement for about 2 years.
What do you mean by a resistor?
Wire it as follows, but be careful, it can spark...
+ from main power wire to + on Cap
+ on Cap to + on Amp
- on Cap to Ground
- on Amp to Ground
If you are going to buy a resistor to charge the cap first, (1K ohm, 1/4W from radioshack, or 12V light bulb), then do the following:
+ from Main power wire to + on cap
- Cap to Resistor to Ground (This is where you charge the Cap, make sure you have the battery connected when you do the resistor/ground; after it's charged, disconnect the battery then continue)
Amp - to Ground
Cap + to Amp +
THen re-connect the battery, and you should be good to go. You can skip the charging, but it can/will spark pretty strongly.
- on Cap to Ground
- on Amp to Ground
Amp - to Ground
Cap + to Amp +
surreybrad
Apr 22, 2015 06:40 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
