Where can i find a hole in the firewall?
Old Jun 24, 2006 | 01:48 PM
Chevy16's Avatar
i need to find a hole for the power wire for my amp and i dont really want to go digging and F*** something up so does anyone have any suggestions for a 1996 camaro where to run the power wire? about where at and if you have pics that would be even better!
Old Jun 24, 2006 | 02:48 PM
Blue89Bird's Avatar
Re: Where can i find a hole in the firewall?
unbolt the ecm on the passenger side firewall and use the grommet those wires go through.
Old Jun 24, 2006 | 06:57 PM
Chevy16's Avatar
sorry for the stupidity but whats the "ecm"?
Old Jun 24, 2006 | 11:50 PM
nervekiler's Avatar
its on the passengers side of the engine bay. right in the back cornor on the fender. uses two 10mm bolts and it looks like a small computer brain (thats what it is).
unbolt it and then you have acess to a factory rubber grommet just run the wire through there.
Old Jun 25, 2006 | 01:14 AM
Rashiki's Avatar
Yep, that's what I did. You have to pry the carpet back up under the passenger side dash towards the outside of the car/firewall. I can't remember, but i'm pretty sure you have to take the kick panel off too.
Old Jun 25, 2006 | 11:58 AM
Chevy16's Avatar
alright, cool, thanks guys
Old Jun 29, 2006 | 07:57 PM
wakebordr2006's Avatar
drilled a hole on drivers side. sounds much easier then the passenger side.
Old Jun 30, 2006 | 10:37 AM
nervekiler's Avatar
except one problem the battery is on the passengers side. dont want to route power cable clear the the wrong side of the car for no reason
cool thing is i dont even have to drill a hole just poke something through the grommet takes me 10 minutes tops to dissasemble poke the hole then reassemble everything.
Old Jun 30, 2006 | 03:45 PM
Chevy16's Avatar
it was pretty easy and man oh man does it sound good thanks for the help
Old Jun 30, 2006 | 09:45 PM
detroit1994z28's Avatar
There you go
http://www.ws6.com/batt-relocate.htm
Victor Lamb
Aug 26, 2017 02:52 PM
eazyZ
Mar 1, 2015 07:12 AM
pimpss96
Feb 12, 2015 01:28 PM
rjc1629
Jan 27, 2015 10:46 AM
Timberwolf
Aug 9, 2002 11:24 AM
