What size are the door speakers in a 99 TA?
Old 02-06-2004, 04:18 PM
pbjones81's Avatar
Im wanting to replace the old crappy paper speakers in my 99 trans am. What size are the stock ones? also, I have heard that aftermarket speakers never fit good in the doors. Is this true? and is there anything to buy to make them fit better? like an adapter bracket? thanks
pbjones81 is offline
Old 02-06-2004, 04:36 PM
97FormulaWS-6's Avatar
1st off what system do you have in your car? If it's the Monsoon 10 speaker setup you have to replace the ENTIRE system with aftermarket speakers, or keep the stock speakers.. it sux, but that's how it is..
The Speaker sizes are 6.75" on both the Doors and Sail Panels.
97FormulaWS-6 is offline
Old 02-06-2004, 07:27 PM
Rogue Leader's Avatar
you dont have to replace all of them, look for my thread here about changing monsson speakers....
Rogue Leader is offline
Old 02-07-2004, 07:33 AM
LS1 RULZ's Avatar
You might want to consider making your own baffles to mount the speakers to. I tried using the stock baffles in my '99 T/A and ended up blowing one of my mid-woofers. On long excursions it was slamming into the back of the door's trim panel. This caused the cone to separate from the VC. The baffles I made lowered the speakers an extra 1/4" deeper into the door. The 4th screw I added helps to stiffen the door a little too. I used silicone caulk around the edged of the baffle to prevent any rattles.
Baffles
LS1 RULZ is offline
Old 02-08-2004, 07:03 PM
KillerTA's Avatar
my friend replaced his door speakers with RF's and just plugged them in.
KillerTA is offline
HectorM52
07-30-2017 11:46 AM
stangspank
11-13-2015 01:02 PM
Rod Bender
01-01-2015 03:18 PM
MJ_Z28
08-08-2002 09:07 PM
MilkyClr69
07-29-2002 10:01 AM
Quick Reply: What size are the door speakers in a 99 TA?
