What size amp?
Old Jul 8, 2004 | 12:48 AM
NJTCamaroZ28's Avatar
What size amp?
2 10" Rockford Fosgate Punch Z Subs
What size amp should I get for these to run them to a good amount without risking blowing them?
Old Jul 8, 2004 | 06:10 AM
LS1 RULZ's Avatar
I would recommend at least 300W RMS to each sub. Don't worry about blowing them. As long as you set everything up right and aren't stupid with the volume control the subs will be fine. The 10" Alpine Type-S I'm using is only rated at 200W but my subwoofer amp can deliver 600W
Old Jul 8, 2004 | 09:07 AM
So you would say get like an amp between 600-1000 watts?
Old Jul 8, 2004 | 09:58 AM
LS1 RULZ's Avatar
That would depend on the rest of the setup. If you're just running the HU's power to the main speakers then 1000W would be overkill.
Old Jul 17, 2004 | 03:24 PM
bt96ss's Avatar
Punch Z subs are only rated to handle between 150-250watts. I wouldn't put over 300 on the pair if you want them to last.
Old Jul 17, 2004 | 04:33 PM
LS1 RULZ's Avatar
Thats not really an issue. My Alpine Type-S is only rated at 200W but my subwoofer amp delivers 600W
Old Jul 17, 2004 | 08:23 PM
bt96ss's Avatar
Most people don't have enough self control to put twice the rated power on a sub. The Z series are the lowest fosgate made. They are pretty weak and don't stand up well to abuse. The voice coils are small and won't take much heat. Alpine subs I believe are overbuilt. I had a few type R's they handled over power very well.
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
