Various interior issues
Old Sep 15, 2023 | 08:16 AM
It's Cochese!'s Avatar
While I'm waiting to see if my engine will work again, I'm shifting my attention to checklist items on the interior.
First blush of the car shows the following items not working:
Driver door controls - can operate pass window, but not driver window, door locks, nor power mirror
Driver seat - the middle **** works up and down, but neither of the levers
Radio - an aftermarket Sony unit, turns off if you press it hard. I'm assuming it's just a loose wire
High beams don't work. I've read about the rod in the steering column, will be investigating that vs dead light assemblies
Key chime works, light chime works, power hatch release works. That's all I've been able to test thus far. I have scoured around for ideas, and have found the high beam issue thus far. I have seen where the back of the window/lock switch was posted with what color wires, but haven't been able to make diagnostic sense of it yet (as in, where to test if it is receiving power, etc)
Old Sep 15, 2023 | 09:15 AM
Re: Various interior issues
Did I give you the link to the 1994 factory service manual?
https://www.mediafire.com/?40mfgeoe4ctti
Section 8A has all the wiring diagrams.
Old Sep 15, 2023 | 10:04 AM
I’m sure you did, it just slipped my mind with the crank issue. Looks like I have some bedtime reading material. Thanks.
Z28gr.mans
Jan 28, 2022 02:24 PM
bsmith0404
Oct 23, 2021 01:11 PM
KYWes
Feb 27, 2012 04:21 PM
SmokeyBlaZe
Feb 9, 2011 06:22 PM
95Z28LT1-PA
Mar 11, 2010 11:09 PM
