Sub and Sub box question
Old Apr 27, 2005 | 04:35 PM
camaroblood's Avatar
I am wondering if the bottom (magnet) of the sub is supposed to touch the bottom of the sub box... the faster the reply the better, thank you. PM if you need more details. or email at camaroblood@yahoo.com
Old Apr 27, 2005 | 05:23 PM
shouldaboughtthez's Avatar
Re: Sub and Sub box question
Did you make the box to small. How bad does it touch?
Old Apr 27, 2005 | 05:26 PM
well i found out the box was made, not by me, 9/16's to shallow for my sub so I am seeing if the guy who made it will do anything about it or i will have to make up something
Old Apr 27, 2005 | 07:25 PM
97FormulaWS-6's Avatar
Not supossed to unless it's designed that way on purpose...
Most often it's not supossed to, and is supported soley by the mounting flange.
There are exceptions, but they are very rare.
And being 9/16" too shallow is a lot, and I'm betting the mounting flange isn't even touching the box.
Old Apr 27, 2005 | 10:33 PM
If you look carefully you can see the small space, the guy said he can send me another 1/2 inch spacer and everything will be just fine.
Old Apr 27, 2005 | 11:17 PM
LS1 RULZ's Avatar
Will the added hieght from the extra spacer cause any clearance issues when you flip the enclosure over? Just a thought.
Old Apr 28, 2005 | 08:41 AM
superadobo808's Avatar
Your situation is pretty bad. The bottom of the speaker has a hole that is used to cool the voice coil. If air is not let in and out of that hole, your speaker will over heat really fast and wont be able to handle as much power. If the guy you bought the box from will give you a spacer to put ontop of the box, the speaker will fit. I think it will look ugly, and pose a possible problem when you close the flap.
Old Apr 28, 2005 | 08:56 AM
As is, the box, without the sub, has about 2 1/2 inches clearence between itself and the lock on the back of the hatch, and that is the only thing that will cause a problem, but there is enough clearence. Secondly my sub has a top mounting depth of 7 9/16s with the spacer he could send me it would allow a mounting depth of 7 and 8/16's or 7 1/2. Would this be enough however?
Old Apr 28, 2005 | 09:10 AM
LS1 RULZ's Avatar
As long as the sub's flange seals against the enclosure's baffle and the rear wall of the enclosure isn't blocking the hole in the vented magent, you don't have anything to worry about.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 13, 2015 09:52 PM
TechCam97
Sep 12, 2002 07:20 PM
FiNSTa
Jul 20, 2002 10:57 PM
