stock system help please
Old Mar 18, 2005 | 09:21 PM
SpeedDemon02SS's Avatar
im getting a whinning sound through the speakers when i rev the engine. happens even when the radio is off. im pretty sure it has to do with the grounding on the amp because ive seen this before. can someone tell me the best place to install a ground loop isolator? or if this is something different?
thanks
Old Mar 18, 2005 | 11:29 PM
shouldaboughtthez's Avatar
Re: stock system help please
First off check your ground. Make sure it is good. Then check your RCA's. When they start going bad, they will pick up noise. Do you have the RCA's with the little wire running down the middle of it? If so, that is a ground wire, not a remote wire.
Old Mar 18, 2005 | 11:50 PM
i dont know. i have never actually looked at the amp. isnt in the back, behind the passanger side panalling? This is the stock Monsoon system, i didnt think there were RCA's. where is the ground wire bolted too? can i just add a ground loop isolator there?
thanks again
Old Mar 20, 2005 | 07:51 AM
LS1 RULZ's Avatar
A ground loop isolator has RCA connectors and goes between the HU and amplifier. It does NOT get connected to the amp's ground connection.
If you are hearing the noise even when the stereo is off it is not a ground problem. What speakers are you using? If they are after-market speakers where do you have the crossovers mounted? More details about the rest of your setup would help.
Old Mar 20, 2005 | 09:09 AM
bone stock...500 watt (yea right) monsoon
Old Mar 20, 2005 | 09:28 AM
LS1 RULZ's Avatar
Thats your problem right there. The stock stereo is a POS. Replace ALL of it or don't even bother.
DirtyDaveW
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
CobraEatr
Jul 29, 2002 11:46 AM
