static when engine in running
Old Nov 22, 2003 | 08:56 PM
hawk232's Avatar
my radio has alot of static, but only when the engine is running and only on two stations. i realize this is probably a grounding issue, but where should i start to find out?
Old Nov 25, 2003 | 10:53 AM
PaulN64's Avatar
you off to a good start...check the gound on the radio. You may want to ground it on a different place and see if that helps. Though since it's only coming from two stations, that is kinda weird. Perhaps check the ant connection while you are at it
97z28k&N
Jan 9, 2015 04:58 AM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
Vokabulis
Jul 25, 2002 05:46 AM
