Starter Switch removal bypass
Old Jul 16, 2004 | 01:55 PM
whitemusclez28's Avatar
im having a hard time with the switch on my column that runs off of the rod from the ginition tumbler itsself, so i am throwing it in the trash. i like the idea of the s2000 starter button but i really want a toggle switch that will have an off, run, and start position, with the start having a return on it. now, realizing that i still am going to have to use the key, can i simply run the wires from the harness going into the switch, to a toggle, i am not familliar with using a relay, but if one is nessacary could someone please explain, how exactly to wire it in, i have seen the diagram of the s2000 button but i am not sure if it is going to be the same without the origiona switch in there on the column. i am trying to completley bypass that plastic piece of crap. thank you any help will be GREATLY APPRECIATED.
Old Jul 19, 2004 | 01:25 PM
JamesNobles's Avatar
Re: Starter Switch removal bypass
Well heres what I did...Go directly off your starter. Put in a kill switch where no on one will find it then continue on into the car and mount it somewhere on the center console or even hide that too...but put in a kill switch inbetween the starter and toggle. I have a push button start. So you turn your key forward then hit the push button and boom....you have ignition...takes about 30 minutes or so....
James
Old Jul 20, 2004 | 03:58 PM
lifbcracker's Avatar
Do you have the S2000 push start? I have a diagram and website explaing how to install it but it was for a 98+ f-bod and i have a 97...the wiring is a bit diffferent and I cannot find the red +12v, pink +12v (igniton wire "key on posistion"), and the yellow starter wire...can you help me?? also this is the website i was following http://members.***.net/pitre/s2000sw.htm
Old Jul 20, 2004 | 08:21 PM
I have the push button but it is coming right off the starter though...I didnt tap into any of the ignitioin wires. You might want to check your fuse panel for a hot wire and that pink wire...or check somewhere on the bottom of your steering column
Old Jul 20, 2004 | 09:59 PM
Javelin3o4's Avatar
the wires you were looking for (red/pink/yellow) are in the bundle of wires under the dash probably covered by black tape of wire loom. but they will be all grouped together.
Heathen1
Jan 2, 2016 04:27 PM
Critter
Jul 7, 2015 08:33 PM
timmy39120
May 2, 2015 05:12 PM
lt1matt
Mar 21, 2015 07:35 PM
Caps94ZODG
Sep 7, 2002 10:09 PM
