Splice into Power for Seats
I have a driver's side power lumbar seat, not power tracks. I don't have the pig-tail to plug into the pre-wired power underneath the drivers seat, is there a way I can splice right into it without the pig tail? Does anybody know which wires go to the power and which to the ground?
Use a multimeter to check the voltage. That will tell you which is positive and which is ground. You can cut the connector off and splice right into the wires, but then I would just get the pigtail and do it right, in case you ever have to remove the seat.
From what I can remember there are six wires coming from the seat, just need to check them with the multimeter and then with the two pre-wired harness underneath the seat to see which goes to which, right?
carguyshu
Jan 22, 2017 11:19 AM
Jan 23, 2015 01:13 PM
bossco
Nov 29, 2014 10:18 AM
