Speakers not putting out sound anymore
Old Feb 16, 2009 | 05:23 PM
jmmullin's Avatar
One day the speakers worked, the next they did not...
All speakers and the head unit are aftermarket, and installed by a reputable local audio shop back home. I would just go back to them to get it fixed, but "home" is an hour away... so I'll check to see if any of you have suggestions of where to start debugging this...
I've got regular old speakers in the front doors of the Camaro, component speakers with crossovers in the side panels, and the stock speakers in the rear hatch with 2 subs in the T-Top glass area. A 1000 wt amp powers the subs, and a 500 wt amp powers the other speakers.
Right now the only thing in the vehicle that makes sound speakerwise are the subs, but the sound is VERY minimal; very quiet... I can tell what song is playing from the bass beat that comes out of the subs, so I guess it is receiving a signal from the radio... I checked the fuse coming off the battery, and the fuse coming from each amp; all seem to be working correctly, but I could be wrong.
Any suggestions? I probably haven't put up enough information but if you need to know anything else to form an opinion I'll do my best to accomodate. Thanks.
Old Feb 17, 2009 | 12:42 PM
The Captain's Avatar
Pull out your CD player and check the connections behind it, thats where I would start. If you have a different CD player or a factory radio swap them out and see if your speakers start working again. If they do you know its a faulty CD player.
Old Feb 18, 2009 | 10:52 AM
Chevyssoccer's Avatar
If there is an amp for the regular speakers, the problem is more than likely there since the radio is sending signal to the subs. could be a bad speaker grounding out and causing the amp to go into protect. Is there a light that says protect or a different color than normal on the amp?
Old Feb 18, 2009 | 01:55 PM
jmmullin's Avatar
Why yes, yes there is... I'll probably be taking the car back to the shop that did the work this week and get them to check it out.. Thanks for the input!
Collector Car
Jan 5, 2015 10:58 AM
Rod Bender
Jan 1, 2015 03:18 PM
Evilfrog
Aug 7, 2002 11:36 PM
CamaroKiddZ28
Aug 7, 2002 10:17 PM
Anderson
Jul 28, 2002 10:57 AM
