Rewiring my car..
Old Dec 17, 2003 | 05:02 PM
mirroredfire2's Avatar
Rewiring my car..
This is a 98 trans am. okey found out my amp went to **** and its making the two front speakers buzz.. like really bad.. so im going to replace the amp.. only problem is the wiring is going to suck and ive never done it to any car before.. can I use the wiring that is already there from factory back to the speakers and just run the amp preouts from my HU to the amp in the back?
Okey heres my plan.. im going to have 2 amps one for the speakers one for the subs.. ill run the two preouts to the back of the car for the two amps and then connect the speaker amp to the factory wiring by snipping the wires from the connector of the old amp (already have the wiring diagram).. then replace the speakers with aftermarket ones. Does this sound right? THanks!
Old Dec 18, 2003 | 09:42 PM
PaulN64's Avatar
if you are just replacing the an amp, there's no-rewiring needed. Just put the new amp on and hook everything back the same way. If you are talking about adding a second amp, then just run another set of RCA if you have a sub output on your HU. You might have to get a distirbution block if you are running a second amp and might have to upgrade the wire size as well. You can use the same remote wire from the first amp to the second amp
blac94Z
Jun 30, 2015 07:38 AM
grabbem88
Apr 16, 2015 06:57 PM
rwferguson43026
Feb 6, 2015 10:06 AM
ledfootz28
Apr 8, 2003 12:21 AM
kurob25
Mar 2, 2003 07:54 PM
