Replacement Speakers
Old Apr 24, 2006 | 08:59 PM
wrenchpiggy's Avatar
Unfortunately audio systems are black magic to me. I know so little it scares me. Both front speakers in my '95 TA are blown. Are there after market speakers I can purchase that will be plug and play. I don't want to cut, splice or solder. Can anyone help out.
Old Apr 25, 2006 | 12:49 AM
eagleknight97's Avatar
Re: Replacement Speakers
Crutchfield sells adapters for your speakers so they plug directly in to your cars wiring harness. HOWEVER that is only for your sail panel speaker and the rear hatch speakers, NOT the front door speakers. You need to cut and splice some wires to do those. However, if you call up Crutchfield when you put the speakers in, they will walk you through the process to do what you need to do. Its pretty easy, just seems a little tricky if youve never done it before.
Rod Bender
Jan 1, 2015 03:18 PM
Jazsun
Dec 29, 2014 12:14 PM
redcamaro9090
Aug 27, 2002 10:16 PM
Brad 97z
Aug 10, 2002 09:58 AM
