rear defog melts 30 amp fuse! WTF?
Old Apr 17, 2013 | 07:09 PM
firebirdStud's Avatar
Question rear defog melts 30 amp fuse! WTF?
So, This seems to be a reoccuring issue. In my fuse panel, the 30amp fuse for the power seats and rear window defogger keeps melting. I dont have power seats, so I know it is only the rear window defogger giving me the problems.
What gives? This is the second fuse that is melting due to this issue!
#12 in this pic
The fuses. The really effed up one was the first to go, two years ago. Now the second one has signs of boiling
Old Apr 18, 2013 | 07:13 AM
Re: rear defog melts 30 amp fuse! WTF?
The panel label indicates it should be a circuit breaker ("BKR"), not a fuse. Have you tried using the correct piece?
Old Apr 18, 2013 | 10:01 AM
Hey Fred. Long time no talk!
I have finally remembered why I put the fuse in the place of the breaker. Took a while, since I did it years ago, and Ive been out of the country (and away from my car) 2 1/2 years of the past 4!
Anyways, here is the link to the thread I found addressing this issue:
Defroster switch... - LS1TECH
I was having the problem where the defroster would turn off after only 30 seconds or so. After finding that thread, I put the fuse in.
Interesting though, nobody on that board is having problems with the fuse melting?
Thoughts?
*edit* since I found the solution over there a long time ago, I posted in that thread to see if anyone else has experienced this problem too.
Thanks!
Cody
Red Hawk 94
Mar 18, 2019 04:03 PM
NewsBot
Jan 8, 2015 11:29 PM
regular Joe
Aug 8, 2002 03:47 PM
Krab
Aug 5, 2002 12:08 AM
