quick amp question
Old Aug 1, 2006 | 09:43 PM
CLEAR's Avatar
quick amp question
im hooking up an amp to a factory HU. im using the high level input on the amp. there is an extra wire that says 'signal ground'. it is black and the instructions dont say anything about that wire. do i just ground it? its in the harness with the L and R speaker inputs
Old Aug 2, 2006 | 07:13 AM
LS1 RULZ's Avatar
Re: quick amp question
Who makes this amp and what is it's model number? Does the HU use a common ground for the speaker connections? In other words do the speakers each have their own + wire and a - wire that gets connected to chassis ground? If that's the case you cannot use the amp and HU together.
Old Aug 2, 2006 | 07:35 AM
CLEAR's Avatar
its a crossfire tek752. each speaker has its own + and -. the amp is wired for that but it has an extra signal ground wire just like the line output converters ive seen.
Old Aug 2, 2006 | 07:43 AM
LS1 RULZ's Avatar
I've never seen an LOC that had a signal ground wire like that. All the LOCs I've seen have a + and - wire for power and ground and then the wires for connecting the speaker level inputs and the RCA outputs. I don't see why there would be an additional wire for "signal ground". Hmmm
Old Aug 2, 2006 | 04:11 PM
blkbrd's Avatar
i agree i've never seen that either.
i would call the crossfire tech line as this may be somthing new to their amplifiers.
Old Aug 2, 2006 | 07:04 PM
CLEAR's Avatar
found out by calling the supplier of a LOC. they said its a ground for IF you are picking up engine noise
RUENUF
Mar 13, 2016 03:39 PM
silvermansteve
Mar 4, 2015 05:02 PM
94Form
Feb 10, 2015 11:23 PM
NewsBot
Jan 8, 2015 11:29 PM
Absolute Z28
Jul 19, 2002 02:21 PM
