Question about grounding
Old Jan 20, 2004 | 05:41 PM
Cerwin Vega Fan's Avatar
Question Question about grounding
I have three things I need to ground (2 amps and a cap.) The problem is that it is going to be hard to get proper grounds for each of the three. I was wondering would be ok to use a grounding lug and combine all three grounds into one? Or would be better to ground each one individually?
Thanks,
Chris
Old Jan 20, 2004 | 06:43 PM
LanceJoker's Avatar
It's a decent ground if you do it right,but,scrape off the paint around the seatbelt bolt.You can use those on each of the rear sestbelts for a rear ground.Just make sure you get solid contact with no paint under between the two metals.
Old Jan 20, 2004 | 06:46 PM
LS1 RULZ's Avatar
ALWAYS ground your amps, EQ's, etc. to the same spot. This helps to prevent ground loops.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Injuneer
Dec 15, 2014 09:36 AM
Hurin
Dec 13, 2014 07:38 PM
DrMilhouse
Oct 2, 2002 05:03 PM
Brian Demeter
Aug 21, 2002 02:07 PM
