question
Old Sep 17, 2007 | 06:30 PM
yourmom's Avatar
question
i have two 10 type r's and was pushin them at like 250rms and turned the bass up sounded a little distorted anyone have a idea??
Old Sep 17, 2007 | 08:31 PM
bmnicolosi's Avatar
underpowered subs, wrong box for sub/power setup
Old Sep 17, 2007 | 09:41 PM
fredmr39's Avatar
they would not sound distorted if they were underpowered
Old Sep 18, 2007 | 12:08 AM
bmnicolosi's Avatar
if he cranked it up too loud and the subs were underpowered they could make a distrotion/bottom out noise.
Old Sep 18, 2007 | 12:09 AM
bmnicolosi's Avatar
underpowering is worse than slightly overpowering
Old Sep 18, 2007 | 01:10 AM
fredmr39's Avatar
Well obviously anything is bad, if not done properly. The statement you implied was "under-powering is bad", rather than saying "improperly powering a sub is bad." If you under-power a sub properly, there are no issues at all. If you have a sub that isn't getting as much power as you like and improperly crank the gains up on your amp -- then you will begin to see clipping/distortion....not due to the fact that it is underpowered, but because you are trying to get more out of the system than it is capable of.
So rather than saying "under-powering is bad"...look at it more as just something that may prompt someone to improperly power a sub (or whatever).
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
