noise reduction help.
Old May 3, 2008 | 01:39 PM
cridom's Avatar
im trying to make my car quieter from road sounds and rattles etc...
its kinda loose now so i want to get those mats that you put in carpets and doors.
which ones do you recomend and are they easy to put your self?
thanks
Old May 5, 2008 | 08:20 AM
THE_RUCKUS's Avatar
in my old TA (you'll laugh) i put actual indoor carpet padding under the carpet. it helped! then I went for new seals and weatherstripping and dynamatted the hatch area and door panels. suddenly it didn't sound like a tin can.
Old May 5, 2008 | 05:30 PM
cridom's Avatar
hehe lol btw did it get like a bmw quiet or just preatty quiet.
my moms got a 97 bmw and its awsome for daily drives, i wanan try to get as cloase to it as posible
Old May 7, 2008 | 12:35 AM
bluz28's Avatar
This is a hard top right?....
If it is, drop the headliner and stuff a good pound of polyfil in the center section of the roof. Then completely cover the left, and right t-top areas with 2 layers of "Second Skin Damplifier", and for the final touch put a layer of "Second Skin" under the dash pad. I just did those two areas on my car about a month ago. These were the only two areas in my car I Had not sound deadened yet, an IMO It made a noticeable differance. Then put 2 layers on the inside of the outer door skins, 2 on the floor, at least 1 layer in the "body bag area" , and also the whole spare tire area, then a layer or 2 on the rear deck area, also the behind the sail panels , and in the area behind the sail panel speakers. Then from under the car, with a can of spray on bed liner spray the under side of the "body bag area". make sure you also spray it really good up above the left and right exhaust tailpipe area.(I used a whole can in this back area) make sure you tape up your exhaust pipes to keep the bed liner off them. If you're not tired yet, jack up the car and spray a fresh layer of undercoating up in both rear wheelwells. "Man!.. I'm tired already!"...LOL!
Kinglouui
May 26, 2016 11:05 AM
David Dempsey
Mar 12, 2016 12:42 AM
truecontr3
Oct 11, 2015 09:30 AM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
