No radio or chimes...
Old Jul 14, 2011 | 09:55 PM
rpinson's Avatar
I got into my car yesterday at the drug store and put the key in the ignition with the door still open. Everything was working fine and as I started to shut the door, I lost power to the radio and the chime for the key in the ignition stopped working. I've replaced the RAP module before, but I don't think that's the culprit here. The windows and door locks still work, but I cant lock the car with the key fob (no alarm, just keyless entry).
Any idea where I should start? Just happened tonight and it was dark, but I'll tackle it tomorrow after work. Hoping that it's just a fuse or something that happens to control all of that.
95 z28, btw if that matters any.
Thanks guys.
Old Jul 27, 2011 | 02:11 AM
bobbyk3lly's Avatar
Re: No radio or chimes...
sounds like the radio fuse blew, if not check for power going to the constant hot area of the fuse block. if theres no power there then that could be your problem... i know that before i rewired my camaro my int lights, radio and pinging sound all would not work unless i hooked 12v of power to the power wires going to the radio, which told me i had a chewed wire somewhere...
hope this helps..
nosliw
Mar 9, 2016 04:56 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
Bxlt1
Sep 10, 2015 08:16 AM
