no bass?????
Old Oct 18, 2003 | 08:31 PM
CrAkD X 95TA's Avatar
no bass?????
ok I got 1 10" RF POWER HX2 and a Rockford Power 1000bd 1000 watt mono block....i cant even hear the sub no matter what the gain is set to and the subwoofer level on the HU all the way up.....if i look at it its going i can see the speaker moving and i can hear it but only if im in the trunk not well driving.....someone here told me the amp is stable at 1 ohm so i wired it to 1 ohm.....my first thought was maybe its not getting enough power cause i have 3 amps going and the amp is only getting a 8ga wire off a dist block splitting a 4ga...but in my old setup i had 3 amps going and my 2 12"s pounded....so now im thinking maybe the new 1000bd isnt 1ohm stable....would that be whats causing it to barely move the sub?
Old Oct 18, 2003 | 09:57 PM
LS1 RULZ's Avatar
I'm assuming this is a dual voice coil sub? If so, have you checked to make sure you didn't connect one of the VC's backwards? If the VC's are not in phase with each other it will result in almost complete cancellation and very little movement by the cone if any.
Old Oct 18, 2003 | 10:26 PM
hmmm what do u mean by backwards???? I connected positive to positive negative to negative...but it is possible because my buddy helped me do it and he had no clue what he was doing and he connected them to the box and i didnt double check im going to open the box and see.....thanks
also yes its a dual 2ohm sub
Old Oct 19, 2003 | 02:12 PM
firebirdude's Avatar
I own the bd1000a1 and YES it is 1 ohm stable. And good god man. Upgrade that damn power wire.
Old Oct 19, 2003 | 02:16 PM
Knowklew's Avatar
I thought you run one wire from the postive on one voice coil to the negatvie on the other and then take the remaining negtive from one coil and the postive form the other coil and wire that up???
Old Oct 19, 2003 | 02:26 PM
That would be wiring the voice coils in series. This would give him a 4 ohm load. Check out www.jlaudio.com They have some wiring diagrams you could check out.
Old Oct 19, 2003 | 03:13 PM
well i ended up taking out the sub and wiring it for 4ohm and still getting nothing...so then i messed around with the filter and fixed it i got tons of bass now at 4ohm and id rather just leave it at that cause i may add another 10" on the other side and if u add them together wired at that then itll be 2ohm sorry the "stupids" just set into my head for a minute lol.....but to upgrade the power wire id have to run another 4ga wire right to the amp lol i dont want 100 wires going thru my car. only other way i can think is getting a 0 guage and splitting it to 2 4 ga but even with that id have to take everything out cause a 0 guage isnt gonna fit under the trim panels LOL im gonna have to run it under the carpet....to much work lol
Old Oct 22, 2003 | 12:27 PM
Ted J's Avatar
He said the 1000bd though and that's only stable down to 2 ohms.
Old Oct 22, 2003 | 03:31 PM
I'm not sure about the new model amps. I have the 2001 model. The year before they went with the oval shaped end pieces. Yuk! Some people call it the bd1000 for short, so I figured that's what he was asking about. Aren't the new bd1000's two channel? Maybe not.....
Old Oct 22, 2003 | 03:41 PM
Ted J's Avatar
I don't know the exact years they changed but they went in this order:
bd1000
1000bd (for at least 2002)
1001bd (for 2003)
So there is a difference and the 1000bd and 1001bd are both Class D mono amps that are 2 ohm stable.
Old Oct 22, 2003 | 03:44 PM
bd1000
1001bd (for 2003)
Ahhhh OK. So the 1000bd and 1001bd are only 2 ohm stable. Well then, glad I got the bd1000!!!
Old Oct 22, 2003 | 03:51 PM
i like the ovals better I think the 2001 amps are nasty looking.....and i think the 1000bd and 1001bd are both 2003 amps just different models
Old Oct 22, 2003 | 03:53 PM
Ted J's Avatar
The one at the end of the number shows it's a newer year, probably the same amp underneath would be my guess.
I have a 1000bd (made in 2002) I used for a bit and the newer 1001bd's have different endcaps and I think are a slightly different color.
Old Oct 22, 2003 | 03:56 PM
yeah the 1001bd is silver not grey and I think its square not oval.
Latronaxe
Jul 17, 2015 11:55 AM
GoFast908Z
Dec 11, 2002 11:04 PM
Achilles97
Sep 16, 2002 12:27 PM
Achilles97
Sep 13, 2002 10:49 AM
NJLT1SS
Sep 11, 2002 02:29 AM
