new system
Old Dec 11, 2002 | 07:33 PM
notstock4long's Avatar
new system
I plan to spend about $1500 on my new system. I want to get two 12" brahma subs, and two rockford 1000bd amps. The amp put out over 1000w @ 2 ohms, so I could run one to each sub right. The subs have dual 2ohm voice coils, so what ohm would they run best at, 2 or 1, or 4? Not really sure how that works. Does anyone have any good suggestions on what brand I should go with?
Old Dec 11, 2002 | 07:55 PM
So if I run the bramhas in series they will be four ohm, right? Is there anyway to make them run at two ohms, like wiring them parallel?
Old Dec 11, 2002 | 08:04 PM
LS1 RULZ's Avatar
A sub with dual 2ohm VC's can only be run at 4ohm (VC's in series) or at 1ohm (VC's in parallel).
Old Dec 11, 2002 | 09:54 PM
firebirdude's Avatar
Ls1 Rulz is correct. Each Brahma can be wired to either 1 ohm or 4 ohms. The bd1000 is stable to 1 ohm but will still put out the same power. At 4 ohms it will only put about 500WRMS. Just curious.... why the bd1000? Getting a good deal on them? Why not the Adire/Ampman Revolution? Cheap, tons of features and more power. Check em' out at www.ampmanaudio.com $359 shipped. 1500+WRMS at 1 ohm. You want to spend $1500 on the subs and amps? Or on the WHOLE system?
Old Dec 12, 2002 | 04:45 PM
Thanks for the reply. I will end up spending about $1500 on the bass part of the system. Not head unit and regular speakers.
Old Dec 12, 2002 | 04:48 PM
I have heard good things about mempis, but I will look into the ones you mentioned. I really want an amp that puts out what it says it does, unlike kenwood and stuff like that. Any other suggestions.
Old Dec 12, 2002 | 04:53 PM
rthompson's Avatar
The Revolution will be hard to beat for the $$, but you can look into the Memphis 1000d, crossfire 1000d, DEI 1100d, cadence A7HC, Avionixx 1200.2 class T.
Old Dec 12, 2002 | 05:05 PM
ibanez6rg's Avatar
You might want to consider throwing in a couple caps in there also
Old Dec 13, 2002 | 03:28 PM
With two 1k+ amps he's gonna need a little more then a cap or two. A H/O alt. is in order here.
Old Aug 30, 2003 | 11:15 AM
Okay, now I am looking into this again after my unexpected engine death. I am still considering the rockford 1001BD amp, or maybe the memphis 1000W amp. Does the rockford amp have to be at 14.4V to get the full 1000W?
Also, where would I get a high output alternator, and how much would it be? thanks
Old Aug 30, 2003 | 07:32 PM
E-mail my buddy dominick at dominick@tds.net Tell him I sent ya and he'll hook it up!
malikot02SS
Aug 15, 2015 01:11 PM
350350
14
Aug 11, 2015 12:03 PM
MikeWhitener
Aug 2, 2015 06:17 PM
RUNMYTA
Jul 15, 2015 07:50 PM
