new sub and used amp...
Old Feb 24, 2006 | 11:46 AM
DiabloGT's Avatar
the car was installed with 14 i think or 12 gauge speaker wires and this is what it was on a 200watt rms powered bazooka, but it was my uncles so he took it back, and now it is a 250 watt rms bazooka with a pioneer 800 peak and 360rms amp, and when i installed it i didnt really notice a difference without them...? my friends brother says to install 4 gauge wires in it, what should i do?
thanks
Old Feb 25, 2006 | 06:31 AM
LS1 RULZ's Avatar
Re: new sub and used amp...
12 and 14 AWG wire is fine for speaker wiring. 4 AWG power cable is what most people use for their main power cable to the battery. If your power cable is smaller than that I would upgrade it to 4 AWG. What most folks do is run 4 AWG from the battery to a distribution block in back. Then they typically run 8 AWG from the D-block to each amplifier.
Old Feb 25, 2006 | 03:45 PM
DiabloGT's Avatar
do you know of where i can get a cheap block and 4 awg, ad 8 awg wiring? thanks
Old Feb 25, 2006 | 03:58 PM
LS1 RULZ's Avatar
I get my supplies locally at Parts Express
D-Block
Red 4 AWG Part #100-196 for Black
Red 8 AWG Part #100-174 for Black
Old Feb 26, 2006 | 11:16 PM
DiabloGT's Avatar
how many feet do you think is a good amount for the 4 gauge wiring?
thanks
p.s. do i only use one distribution block
Old Feb 27, 2006 | 06:01 AM
LS1 RULZ's Avatar
It depends on where you want to place the D-block. I think I ran about 15' from my battery to the spare tire area. Then I ran 8 AWG from there to each amp. I'd say 3' to one and about 6' to the other.
I only use one D-block for my + power wire. Some folks also use one for their ground connection as well. I grounded both my amps to the rear hatch release.
detroit1994z28
All Non-Automotive
Feb 1, 2013 12:45 PM
BigYellowBlur78
Jan 17, 2009 03:37 PM
chesee48
Jul 14, 2008 09:40 AM
97ramairta
Feb 19, 2008 06:33 PM
