power cells.....
Old Jan 7, 2009 | 01:09 PM
BigYellowBlur78's Avatar
power cells.....
does anybody know anything about power cells... i was thinking of installing 2 Kinetik HC800 power cells in my truck one for each amp...
Old Jan 7, 2009 | 06:35 PM
4thgencamarofan's Avatar
I'm not to sure on the batteries but 950 cranking amps should be fine. What kind of amp are you going to be running??
Old Jan 7, 2009 | 10:47 PM
I have two 12's hooked up a Alpine MRP-M450 amp and another 12 hooked up to a Power Acoustik TS1440-2 amp, which both are hooked up to a 20 Farad Boss Capacitor......
Old Jan 8, 2009 | 03:40 PM
I would assume that the battery would be fine for your setup.
Old Jan 8, 2009 | 10:21 PM
is it like a battery or a cap? how does it recharge if its a battery, cause don't you hook up both the ground and power of the amp to it....?
Old Jan 9, 2009 | 04:11 PM
A cap basically is a battery. You to charge it just like a battery too. If you don't know how there should be a little tiny wire with your cap. Ground the cap and connect the wire to your power wire and then to the cap. Yes the amp does hook directly up to the cap but don't have it connected during charging. When you charge the cap let go of the wire really quick cuz it get REALLY HOT, REALLY QUICK!!!!!!! You don't have to ground the amp to the cap but you can if you want to.
Any other ?s..go ahead and ask away.
Old Jan 16, 2009 | 11:50 PM
how does it stay charged if its not hooked up to the battery?
Old Jan 17, 2009 | 03:37 PM
You mean lik,e if you take it off of your setup right??? Disconnect it from the power wire???? It doesn't stay charged it will discharge itself.
To tell you the truth that cap probally isn't going to do anything for your system. Here's a good read up on that:
http://www.ls1tech.com/forums/stereo...capacitor.html
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
NewsBot
May 16, 2015 03:40 PM
XtremeLt1
Sep 13, 2002 08:50 PM
