New Stereo Enclosure!
Old Oct 13, 2006 | 11:45 AM
shock6906's Avatar
Well here's the pictures of my new stereo enclosure.
Everything on this setup was designed so it can be taken apart easily. The face panel over the amp comes off to expose the wiring underneath. The amp rack is a seperate piece from the subwoofer box and comes out easily without having to pull the subs out. More pics in the cardomain link in my sig.
Old Oct 18, 2006 | 07:23 AM
Red95M6Z28's Avatar
Re: New Stereo Enclosure!
I dont know if you were looking for comments or not but here goes......
Brilliant job on the rear part of the stereo! If the piece where the amps are mounted went all the way to the back of the car(around the subs of course) it would like 100% professional!
Whatever the thing sticking out of your cig lighter is looks like doo-doo. Find a different way to run whatever that is.
Im not a fan of painted interior pieces......but if thats your thing.......
Very, very nice job overall!!
Old Oct 18, 2006 | 03:21 PM
2000GTP's Avatar
The enclosure looks great.
Old Oct 22, 2006 | 11:50 PM
shock6906's Avatar
Thanks for the compliments. I designed the amp enclosure and box to be removable if need be and everything can be taken apart an easily accessed. The cigarette lighter adapter is easy to take out and hide under the shifter plate. It's really for a CB radio that I use for the PA function. I just like screwing with people sometimes. I put it in the center console and I just did the adapter plug so everything can be easily removed if I didn't want it in there anymore.
Old Oct 30, 2006 | 08:25 AM
RKPsk8er's Avatar
everything looks really nice. the only thing I would do is cut part of the amp rack off so its even with the edge of the box. I like your setup
Old Oct 30, 2006 | 08:51 AM
JakeRobb's Avatar
Super Moderator
Looks good. Do the amps get enough airflow for cooling?
Old Oct 30, 2006 | 09:31 AM
shock6906's Avatar
I would imagine so, all the cooling fins are exposed on the top there...I also don't really play it that loud a whole lot anymore. The back side of the amp rack is also open so there's a gap between the seats on the sides where air can get in and out. I may put some fans in there if needed, but I don't think it would be an issue.
Old Oct 30, 2006 | 09:44 AM
JakeRobb's Avatar
Super Moderator
Aren't there larger cooling fins on the sides? IME, the MOSFET transistors (i.e. the source of all the heat) in car audio amps are typically mounted along the sides of the enclosure, and the real cooling fins are on the sides. The ribs along the top surface of the amp are largely decorative.
Old Nov 2, 2006 | 07:20 PM
shock6906's Avatar
Actually the cooling fins aren't that large and there's only three rows of them on top of that. I've played the system for the last couple weeks and haven't had any issues with it. Still, if it comes down to it, I could put some fans in there but I don't see the need right now.
Old Nov 3, 2006 | 01:31 AM
Camaro_Guru16NY's Avatar
enclosure looks nice but im not a fan of the blue trim pieces lol
-john
RUENUF
Mar 13, 2016 03:37 PM
Greg88
Sep 20, 2015 07:14 PM
cmsmith
Sep 14, 2015 09:25 PM
Bxlt1
Sep 10, 2015 08:16 AM
WPHIG2
Aug 27, 2015 06:37 AM
