Monsoon
Old Oct 11, 2003 | 10:57 AM
  #16
bond449798's Avatar
so what would be some good after market speakers to replace them all ?
Old Oct 11, 2003 | 11:41 AM
  #17
Lan01z's Avatar
Originally posted by CODY BEHNKE
It is a small sub called a midrange, the 6.5 speakers are also basically a midrange too.
Well, um... Just what does the term "midrange" mean to you. A midrange speaker would have the center tone coming out of it, right? Its for voices and instrument sounds.. The tweater would be for the high pitched symbol sounds along with higher voices. I would consider the 6.5's they have to be subs since all that really comes out of them is bass and the lower range tones. Size doesn't make a sub a sub Take for instance bass tubes. They make 6.5" subs in that size.
Old Oct 11, 2003 | 05:56 PM
  #18
lastZ's Avatar
those speakers are not subs...the ones between the front and the back seats are....6.5 inch sub....and they are nothing to write home about...
Old Oct 11, 2003 | 06:43 PM
  #19
missingz's Avatar
good luck just replacing the speakers alone, Not unless you replace them with other monsoon speakers other wise to install new speakers you will have to run all new wire to each speaker.
Old Oct 11, 2003 | 06:57 PM
  #20
bond449798's Avatar
Run new wire ? y ?
Old Oct 11, 2003 | 07:18 PM
  #21
SpecForceZ28's Avatar
My sail speakers have never worked since the first day I bought my car brand new.
Old Oct 11, 2003 | 07:51 PM
  #22
JustAnotherT/A's Avatar
Originally posted by bond449798
Run new wire ? y ?
lets just say good luck getting the wires off if you dont want to cut em in half..
Old Oct 12, 2003 | 06:03 PM
  #23
Rogue Leader's Avatar
umm... this post is dripping with MASSIVE miscoceptions.
first read this post http://web.camaross.com/forums/showt...hreadid=177382
I made that to explain about replacing Monsoon Speakers.
As for the Speakers the front is a component tweeter and Midrange, the FAR back (trunk) is a component tweeter and midrange, and in the middle (sail panels) are 6.5 inch DVC Subwoofers.
You DONT have to run new wire, you DONT have to buy a new headunit. Cut the harnesses off the speakers you remove right near where they connect, then crimp on some connectors and attach to the new speakers. Its not hard. Just make sure you buy the RIGHT kind of speaker.
Old Oct 12, 2003 | 08:56 PM
  #24
bond449798's Avatar
so what about these u think they fit
http://www.crutchfield.com/cgi-bin/S...406#morephotos
Old Oct 12, 2003 | 09:39 PM
  #25
only stockers will fit aftermarkets will require modifications. GM did this so you have to go back to them and buy more stuff from em.
Old Oct 12, 2003 | 10:34 PM
  #26
bond449798's Avatar
whats the right kind of speaker ? brand or size ? will 6 3/4 fit
Old Oct 13, 2003 | 07:00 PM
  #27
Not true at all.. I installed EVERY SPEAKER in there with NO MODIFICATION at all... Everything bolted up exactly....
Old Oct 13, 2003 | 07:03 PM
  #28
yes thos are the ones i used... read my other post for my reccomendations...
Old Oct 13, 2003 | 07:09 PM
  #29
??? I went to best buy ( worse place to buy any audio crap but I was desperate ) and all the 6.5s for the fronts WILL NOT FIT.... I had to make a custom board...
Old Oct 13, 2003 | 08:39 PM
  #30
I installed the Alpine SPR-170A and they fit exact..... The Alpines are a standard size 6.5, when I worked in my old shop we used em in everything ....
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
97QuasarBlue3.8
Sep 15, 2002 06:56 PM
30thZ286speed
Aug 3, 2002 04:54 AM
Brian-94TA
Jul 31, 2002 02:52 PM
