Installing a BOSE CD player. Not downgrading. Just installing.
I bought one off of ebay for a 97 and older camaro. What bolts/pieces of molding need to come off to take the old tape deck out and put the cd player in? I was never good at figuring that out!
Re: Installing a BOSE CD player. Not downgrading. Just installing.
In my 95 Z/28 I replaced the stock Bose CD player with an after market one and I had to first remove the glove box (3 little 7mm? screws underneath), then on the left side of the inside of the glove box, there are a couple more screws that hold the middle piece that goes around the cd player. Under the steering wheel on the plastic piece there are 2 phillips screws to take out, then a couple 7mm? on the bottom of that same piece. Slide that piece off and then there should only be I think 2 more screws on the left side of the bezel that goes around the CD player. After that, take the middle piece off and there should be a few screws holding the actual deck in there. Thats how it was on mine, and it only takes like 10 minutes to get it all off, if that.
1996LT1Z28
Apr 14, 2015 07:15 PM
CobraEatr
Jul 22, 2002 09:49 AM
