How to install 6 1/2 speakers in a 1997 Z28?
Old Oct 5, 2004 | 07:33 PM
crazypurgatory's Avatar
I just bought some 6 1/2 speakers today and would like to know if I have to
use the adapers to put the 6 1/2 in the doors and the side pillars?
With out doing a hack job on the car!
Or does any body know where I can get them dirt cheep?
Thanks,
Chris G
Old Oct 5, 2004 | 09:03 PM
CamaroSS30thAnn's Avatar
Re: How to install 6 1/2 speakers in a 1997 Z28?
do u wanna know where u can get speakers for cheap?........i belive teh factory speakers are 6.75 and if u buy pioneer 6.5 speakers they already come with the adapter built in it for installation, i got mine of ebay pretty cheap
if u need intructions on how to install teh speakers its easy im just not ure what ur question at the moment is
Old Oct 5, 2004 | 11:16 PM
I want to know if I have to use an adaptor to put the 6 1/2 speakers in my car.
And if so where can I get the adaptors dirt cheep?
I got 4 6 1/2 blaupunkt speakers for $18.92 at brandsmart.$8.88 a pair.
just to get me by till I can get the one's I want I'm into kenwood.
but if I like them I will keep them for the price I can't go wrong.
Thanks,
Chris G.
Old Oct 6, 2004 | 08:55 AM
LS1 RULZ's Avatar
If the factory speaker baffles in your '97 look like the ones in my '99 TA...
Factory Baffle
I would recommend not using them and making your own. I blew one of my mid-woofers because the cone would smack into the door's trim panel on long excursions. I made my own set of baffles that lower the speaker an extra 1/4" deeper into the door cavity. The baffles I made also add a 4th screw to help make the door a little more rigid.
Old Oct 6, 2004 | 11:33 AM
Yep looks like the same speaker baffles from what I can rember from the last time I had the door panel off.
The speakers I have are very shallow so I soun not have a problem like you had.
So the 6 1/2 speakers bolt right in?
Nice T/A does you CD changer skip in the trunk like that?
Thanks,
Chris G.
Old Oct 6, 2004 | 11:53 AM
LS1 RULZ's Avatar
I would still consider making the baffles. The stock baffles are very flimsy. With the addition of the 4th screw and caulking around the baffle's edge with silicone I was able to make my door a little stiffer. The more rigid you can make the mounting surface the better.
I've never had any skipping problems with my changer mounted there. It works perfectly there.
squarehead
Nov 21, 2014 08:02 PM
ScottZ
Mar 3, 2004 01:34 PM
30thZ286speed
Aug 3, 2002 04:54 AM
