High Output Alternator
Old Jul 31, 2003 | 08:36 PM
palehorse's Avatar
Hey, I recently installed 2 MTX Thunder 8000 10" subs, and they pretty much killed my stock alternator which I believe was putting out 105 amps.
So my question is, am I going to need a higher output alternator to handle these, or do you think my alternator wasn't running right in the first place? I really don't know much about these car audio, so I really need some opinions on whether or not to get a new 105 amp alt., or get a higher output alt. If I need the higher ouput alternator, where can I purchase this?
Old Jul 31, 2003 | 09:04 PM
slayer6x6's Avatar
If you alternator was already on the verge of going dead, than the subs probably suck the fork in it. My underdrive pulleys killed mine is 2 days. If you wanted to get a higher output alternator, any parts store should have it (Pep Boys, ABC, etc.)
Old Jul 31, 2003 | 10:57 PM
firebirdude's Avatar
What amp(s) are you running? For the best deal on a high output alt..... see sig.
Old Jul 31, 2003 | 10:58 PM
palehorse's Avatar
Thunder series 8302
Old Jul 31, 2003 | 11:08 PM
If that's the only amp you are running, your alternator must have been bad before you added it. Were your headlights dimming before the alt went out? Shouldn't have been. Not with that size amp.
HectorM52
Jun 23, 2016 08:42 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
themushine
Sep 3, 2002 10:02 AM
themushine
Sep 3, 2002 10:01 AM
ChameleonGreen
Aug 28, 2002 12:21 AM
