Help Quick! Key resistor problems!
Old Jul 6, 2004 | 05:42 PM
  #16
Red95M6Z28's Avatar
I was told after installing the resistor I have to reset something? What is that? Can I disconnect the neg battery terminal?
Old Jul 6, 2004 | 06:25 PM
  #17
944v8inDFW's Avatar
Just a Thought
If you are programming the pcm, be it yourself or someone else, you may consider disabling the VATS in the computer. With Tuner from CATS it is a one click! Makes life easier. Of if you are having one of the programmers on this board give you a new file for the computer ask them to disable VATS.
Just my 2 pennies
Old Jul 7, 2004 | 07:55 AM
  #18
Brent94Z's Avatar
Super Moderator
Originally posted by Red95M6Z28
OK I went to the GM garage and they said my key is a #11. Which is a 4750 ohm resistor. Now, even though my key actually measured 4428 ohms should a try to make the resistors from radio shack total 4700? Thanks everyone!
So long as you are within 10% of the GM quoted value, you are good to go. That is why your current key works even though it isn't exactly 4700
Old Jul 7, 2004 | 08:21 AM
  #19
There is nothing to reset.
liamcg97
Nov 25, 2019 05:55 PM
Lakebratt
Feb 5, 2015 07:55 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
