Comp. system....
Old Dec 27, 2005 | 12:57 PM
  #16
chris96camaro's Avatar
Re: Comp. system....
in the manual that comes with it, it says if you are using 2-channel amp to just use the tweer inputs, then both outputs...
since there is only one set of wires coming from the HU to each speaker i need to know if i just use the tweeter ins?
Old Dec 27, 2005 | 12:58 PM
  #17
VTsullyman's Avatar
Give me than name and model number of the componets so i can read the manual.
Old Dec 27, 2005 | 01:39 PM
  #18
DiddyZ28's Avatar
I would guess, from what you've said about how the X-overs are set up, run your signal wires from the HU to the tweeter inputs, then run speaker wires from your woofer output to your woofers. That seems completely backwards, even to me, but your X-overs are probably set up to split the tweeter input if that's the only power they are recieving. If that is the case then that would be how you do it.
Old Dec 27, 2005 | 01:43 PM
  #19
VTsullyman's Avatar
I talked ot him on AIM and we got it all worked out. You use the tweeter in put for the HU or 2 channel amp and both for a 4 channel amp
jkbadz28
Aug 9, 2003 10:35 AM
81formula'bird
Jul 4, 2003 02:34 AM
81formula'bird
Pacific
Jul 4, 2003 02:26 AM
CamaroRob97
May 31, 2003 12:46 AM
STANGeatinZ
3rd Gen / L98 Engine Tech
Apr 29, 2003 08:03 AM
