Brent's Kills switch? Q's.
Old May 4, 2004 | 04:11 PM
97BBlackZ's Avatar
I was going to attempt to ty this.
And was wundering if i need anything more then just the 30A auto relay i just got Considering this should work for it right?
Old May 4, 2004 | 06:57 PM
Tair's Avatar
yep...should work great as a starter kill....I've used rat shack relays before and they've lasted for quite a while
Old May 4, 2004 | 07:09 PM
97BBlackZ's Avatar
alright so i dont need connectors or anything?
Old May 4, 2004 | 07:40 PM
Tair's Avatar
Do you know how to solder? If you do, you'll just need some extra speaker wire laying around. If you don't have a clue on how to solder, just use crimp-on connectors to attach the wires to the relay.
Old Jun 7, 2004 | 11:01 AM
97BBlackZ's Avatar
What kind of Crimp-on connectors do i need to attach them to the relay? can someone post a picture or something?
Old Jun 7, 2004 | 11:02 PM
convertz's Avatar
you will need the female quick disconect ends (spade) to go directly to the relay, or if u buy a relay with a mount and harness just some simple butt connectors. Some of the 3M scotchlocks may be helpfull for tapping signal/power from the window switch and a ring terminal to make a neat ground connection.
Old Jun 9, 2004 | 11:17 AM
Brent94Z's Avatar
Super Moderator
Something like the blue connector in the lower left of this picture...
http://www.bfranker.badz28.com/fbody/alarm01a.JPG
Also, if you aren't overly familiar with that relay, read up about it here and you'll get some ideas.
http://www.bfranker.badz28.com/fbody/alarm.htm
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
