Bose + Headunit???
Old Oct 23, 2006 | 04:02 PM
StephenDeli22's Avatar
Bose + Headunit???
What is needed to add a headunit to a bose system? I did a search and came up with using this adapter. Is this needed? Ive heard about head units overheating and such with the bose unit. All I want is the ability to play a cd here, the stock cassette deck isnt cutting it anymore.
Old Oct 23, 2006 | 09:11 PM
valter's Avatar
Re: Bose + Headunit???
Never heard about this one, but if it is the same as PAC ROEM-GM21, then it is the only thing you need to hook aftermarket HU to your Bose.
Old Oct 24, 2006 | 04:55 PM
PentaVolvo's Avatar
You should need nothing special I always use a standard wiring harness with no problem. I did this on my buddies 95 with bose over 2 years ago and no problems
Old Oct 24, 2006 | 11:57 PM
What is the difference between a standard wiring harness and the ROEM-GM21? What will be the consequences of using a standard harness over the specialty one?
You guys have been of much help.
Old Oct 25, 2006 | 09:18 AM
valter's Avatar
Standart = just wiring new HU directly to Bose. ROEM-GM21 = compensates impedance difference. A LOT of people run HU -> Bose directly, but I still wouldn't do it. It may cause HU failure and increase distortion.
Old Oct 25, 2006 | 09:29 AM
6SpdLT1Z's Avatar
I'd save your money from the adapter and save up another hundred or two and get you some decent components.
Old Oct 25, 2006 | 04:26 PM
CALL911's Avatar
I have heard there is much involved (meaning more than just installing the head unit itself) when trying to convert a non Bose system car into one.
Is this true past just the head unit and wiring?
(sorry if I am thread hi-jacking here, but I thought it would be relevent)
Quickss96
Jan 29, 2016 05:56 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
cmsmith
Sep 14, 2015 09:25 PM
Bxlt1
Sep 10, 2015 08:16 AM
yosshimura
Aug 14, 2002 07:29 PM
