best way to run 0guage wire in lt1?
Old Aug 4, 2003 | 10:37 AM
got_hp?'s Avatar
whats the best way to run some 2 or 0 guage wire..........will the firewall grommet fit?
will this size wire fit under the trim panels...........im assuming most people run it underneath the door sill panels
just looking for experience before i go and try it myself.
btw, the cable im using has a somewhat smaller jacket than most car audio 2/0 guage...........its about 1/2 or 2/3 inch in diameter
Old Aug 4, 2003 | 10:03 PM
firebirdude's Avatar
Under the hood. Passenger side, close to the firewall. Remove two 10mm bolts holding in the PCM. Slide the PCM to the side and you'll see a rather large grommet. You can fit 1/0awg through there. Run it under the carpet. There's no way in hell your fitting 1/0awg under the door sills.
Old Aug 4, 2003 | 10:06 PM
NineSevenWS6's Avatar
Yeap..and youll need to remove the seat belt bolt. I think its a t-45-50. Theres no way you can get away with running it over, and its a bitch to tuck under.
Old Aug 5, 2003 | 11:05 PM
slayer6x6's Avatar
Have Fun!
Old Aug 6, 2003 | 08:01 AM
LWillmann's Avatar
I ran my 1/0 power cable down the passenger side of the car. I have some pics on my web site of the cable run so you can see.
I didn't remove the seat belt anchor bolt, I tucked it under. I had trouble removing the cover for the bolt so I gave up rather than tear up the plastic.
It fits under the carpet and looks pretty good IMO.
Old Aug 30, 2003 | 03:14 PM
notstock4long's Avatar
Did you build that sub box yourself? If so, so you think you could share the plans? I want to do something similar, but make a fiberglass top, so the subs stick out of the box about 2" and tilt forward a little. Thanks
cmdeshon
Jan 4, 2015 11:15 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
