amp/sub wiring
Old Mar 24, 2004 | 09:45 PM
nominator's Avatar
amp/sub wiring
hi, i have a 95 z with bose sys . i was wondering if you can unplug the rear sub and use those wires as inputs to an amp and then run some 10 inch subs from that aftermarket amp?ive read on here the bose sys is a little different. thanks
Old Mar 24, 2004 | 10:10 PM
Javelin3o4's Avatar
I havnet seen the wires but i can only assume that the gauge of the wire would be too small for an aftermarket amp, you would also need to send signal to the amp from the head unit, and im not sure if a hi/lo will work with a factory amplified system.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
