ACDelco 12 disk changer problem
Re: ACDelco 12 disk changer problem
Is that the stock one? Get better CD's. I use memorex musicCD-r's. they have a blue design on the CD.
Gauranteed to play EVERYTIME.
Some of the other CD-r's (even music ones) will mess up.
Also, start the car before you put the cartridge in. If you put it in, then turn on the car while it's scanning (scanning takes awhile), then it'll mess up the reading.
That's been my experience.
If it's not reading anything, including CD's with no scratches, that have no problems in other devices.. then
1) Are the CD's in correctly? The CD's should be upside down
2) see if you can clean the changer.. blow some compressed air in.. there might be a way to cleanup the lense inside, i'm not sure if it's accessible
3) If it still doesn't work, it's probably dead
They have these cds that you can put in that will clean the lense. Its a better way of doing it over compressed air but both ways will work. Sounds to me like you cna the cds loaded wrong.
Matt97PTA
Sep 8, 2002 03:57 PM
BLUESMAN
Aug 26, 2002 06:07 AM
