94 Bose system..add an amp/sub??
My 94 has the Bose system with the rear woofer and I have an old Punch 225 and a JL 10w3 in a sealed box. I want to add these for a little more thump if its not much trouble. I dont want a new headunit or have to rewire the system. So could I just splice a line-out converter into the signal wire going to the rear Bose speaker to get the signal for the amp? Anyone do this and will that cause any unwanted noise? Any advice is appreciated.
Re: 94 Bose system..add an amp/sub??
Originally Posted by CamaroBoy96Z28
There should be speakers in the sail panels and yes you can splice an LOC into the speaker wires for signal. Should work just fine.
I would just splice a LOC into the rear signal wires, although it might not be a very "clean" signal and could burn out the AMP.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
cmsmith
Sep 14, 2015 09:25 PM
