2 ohm, or 4 ohm
Old Jul 11, 2003 | 04:46 PM
slayer6x6's Avatar
2 ohm, or 4 ohm
My buddy has a 97 trans am with the 8 speaker system. I remember hearing that some of the newer trans am's had 2 ohm speakers. The rear 6 1/2 is blown, so can i replace with a 4 ohm aftermarket speaker?
Old Jul 11, 2003 | 08:58 PM
bighurt1's Avatar
Re: 2 ohm, or 4 ohm
You won't be able to. I'm sure somebody can explaing better than I could.
Old Jul 11, 2003 | 09:47 PM
PaulN64's Avatar
if he has the Bose system, then yeah, they are 2ohms. You can replace it w/ a 4ohm speaker but it just won't be as loud
Old Jul 12, 2003 | 05:50 PM
slayer6x6's Avatar
Do you know of any aftermarket companys that make a 2 ohm speaker, or is he stuck using a 4 ohm and getting crappy sound quality. Do you have any idea of how much a 2 ohm speaker would cost from a dealer?
Old Jul 12, 2003 | 08:13 PM
bighurt1's Avatar
It's going to sound like crap. Trust me! I replaced my middle set of speakers after they were blown with some set of Pioneers and they sounded like crap.
It's best to go back to stock or change your whole system completely.
Old Jul 12, 2003 | 10:31 PM
PaulN64's Avatar
Old Jul 17, 2003 | 11:38 AM
kerberos's Avatar
if you have a 4 ohm tweeter and a 4 ohm 6,5" you can connect them paralell and the circuit will have (1/ 4 + 1 / 4 = 1/0,5 1/0,5=2) 2 ohms
Old Jul 17, 2003 | 11:44 AM
Ted J's Avatar
Doesn't work that way when a cross-over is added into the mix if the cross-overs are designed correctly, passive that is. The amp will still see a 4 ohm load in the situation you describe above.
13qtr
Oct 28, 2016 08:11 PM
fift5
11
Oct 1, 2015 10:31 AM
plattted
9
Sep 20, 2015 11:23 AM
4586
Aug 13, 2015 10:11 PM
RUNMYTA
Jul 15, 2015 07:50 PM
